GhettoSmurf373
Jul 17, 2020Initiate
Chromecast and Mesh Routing issues
If anyone is like me and recently upgraded to the Netgear Nighhawk Whole Home Mesh WiFi 6 (AX1800), you have probably discovered issues with Chromecast. I searched and searched the web and could not ...
pieters
Jan 26, 2021Aspirant
I experience the same issue, but I run in access point mode. So the "LAN Setup" menu item is greyed-out (which is logical...). I found a a work around where I need to enable the guest wifi, but I do not need the guest wifi.
Does any have an solution for this?
