GhettoSmurf373
Jul 17, 2020Initiate
Chromecast and Mesh Routing issues
If anyone is like me and recently upgraded to the Netgear Nighhawk Whole Home Mesh WiFi 6 (AX1800), you have probably discovered issues with Chromecast. I searched and searched the web and could not ...
Rivinence
Jun 13, 2021Tutor
I have the Nighthawk MR62 Bundle (1 MR60 router, 1 MS60 satellite) running firmware V1.0.6.102_2.0.45. I, like everyone else was having issues with my Google casting devices. What ended up working for me was to uncheck "Disable IGMP Proxying". Ever since I did that everything has been running smoothly. I hope this will help someone out there.
- JECaineJun 13, 2021TutorThank you Rivinence,
I unchecked that setting and I will check it in the morning. I will let you know how it goes.
JC- JECaineJun 14, 2021TutorThanks again Rivinence, unfortunately this solution didn't fix the problem I'm having. I'm just going to buy myself some MoCA adapters and go wired. Hopefully that fixes the problem
