GhettoSmurf373
Jul 17, 2020Initiate
Chromecast and Mesh Routing issues
If anyone is like me and recently upgraded to the Netgear Nighhawk Whole Home Mesh WiFi 6 (AX1800), you have probably discovered issues with Chromecast. I searched and searched the web and could not ...
JECaine
Jun 13, 2021Tutor
Thank you Rivinence,
I unchecked that setting and I will check it in the morning. I will let you know how it goes.
JC
JC
JECaine
Jun 14, 2021Tutor
Thanks again Rivinence, unfortunately this solution didn't fix the problem I'm having. I'm just going to buy myself some MoCA adapters and go wired. Hopefully that fixes the problem
