Phil18
Mar 31, 2020Tutor
Combine RAX120 and MK62?
Hey there, is it possible to use RAX120 router in combination with the MK62 Nighthawk Mesh System? I want to use the RAX120 as gateway and the MR60 and MS60 for getting better connection in cellar ...
- Apr 01, 2020
Hi Phil18,
You can use the two products but you will need to set the MK62 as a wireless AP.
Christian
Christian_R
Apr 01, 2020NETGEAR Employee Retired
Hi Phil18,
Christian
- Phil18Apr 01, 2020TutorThank you for your quick answer! And the EasyMesh is also working in AP mode? Is the MR60 some kind of controller or is the rax120 also a controller if both are in AP mode?
