Phil18
Mar 31, 2020Tutor
Combine RAX120 and MK62?
Hey there, is it possible to use RAX120 router in combination with the MK62 Nighthawk Mesh System? I want to use the RAX120 as gateway and the MR60 and MS60 for getting better connection in cellar ...
- Apr 01, 2020
Hi Phil18,
You can use the two products but you will need to set the MK62 as a wireless AP.
Christian
Christian_R
Apr 01, 2020NETGEAR Employee Retired
Hi Phil18,
Christian
Phil18
Apr 01, 2020Tutor
Thank you for your quick answer! And the EasyMesh is also working in AP mode? Is the MR60 some kind of controller or is the rax120 also a controller if both are in AP mode?
