craholtz
May 28, 2020Aspirant
Compatibility with AT&T UVerse
Is Nighthawk Dual Band Mesh WiFi 6 System - 2 pack (MK62) compatible with AT&T
May 29, 2020Guru - Experienced User
Yes.
do you usually have to make changes with the att device to get it working properly? Yes. ATT tends to give people combo units which makes the network run a double nat without some changes to either the att router or the netgear router.
- craholtzMay 29, 2020AspirantCurrently I don’t have a router, just a modem. I’m getting about 40-50 mbps download speed, which is the fastest speed available for my area. I was told that this router would help with all of the WiFi devices running in the house which is about 3,000 sq ft and is two-stories. I just want to make sure it will work with our AT&T U-Verse.
