craholtz
May 28, 2020Aspirant
Compatibility with AT&T UVerse
Is Nighthawk Dual Band Mesh WiFi 6 System - 2 pack (MK62) compatible with AT&T
May 29, 2020Guru - Experienced User
Yes.
do you usually have to make changes with the att device to get it working properly? Yes. ATT tends to give people combo units which makes the network run a double nat without some changes to either the att router or the netgear router.
craholtz
May 29, 2020Aspirant
Currently I don’t have a router, just a modem. I’m getting about 40-50 mbps download speed, which is the fastest speed available for my area. I was told that this router would help with all of the WiFi devices running in the house which is about 3,000 sq ft and is two-stories. I just want to make sure it will work with our AT&T U-Verse.
- plemansMay 29, 2020Guru - Experienced User
again, most of att devices have an integrated router. Which device are you currently using?
- craholtzMay 29, 2020AspirantIt’s from AT&T, a Pace model 5268AC
Which has an integrated router.
You'd need the pace put in "passthrough" mode to disable its routing functions.
Or the orbi put in the Pace's DMZ.
Or the orbi put in AP (access point) mode so only 1 router is in router mode.
