craholtz
May 28, 2020Aspirant
Compatibility with AT&T UVerse
Is Nighthawk Dual Band Mesh WiFi 6 System - 2 pack (MK62) compatible with AT&T
craholtz
May 29, 2020Aspirant
Currently I don’t have a router, just a modem. I’m getting about 40-50 mbps download speed, which is the fastest speed available for my area. I was told that this router would help with all of the WiFi devices running in the house which is about 3,000 sq ft and is two-stories. I just want to make sure it will work with our AT&T U-Verse.
May 29, 2020Guru - Experienced User
again, most of att devices have an integrated router. Which device are you currently using?
- craholtzMay 29, 2020AspirantIt’s from AT&T, a Pace model 5268AC
- plemansMay 29, 2020Guru - Experienced User
Which has an integrated router.
You'd need the pace put in "passthrough" mode to disable its routing functions.
Or the orbi put in the Pace's DMZ.
Or the orbi put in AP (access point) mode so only 1 router is in router mode.
- craholtzMay 29, 2020AspirantI’m not sure how to do any of those things
