craholtz
May 28, 2020Aspirant
Compatibility with AT&T UVerse
Is Nighthawk Dual Band Mesh WiFi 6 System - 2 pack (MK62) compatible with AT&T
May 29, 2020Guru - Experienced User
again, most of att devices have an integrated router. Which device are you currently using?
craholtz
May 29, 2020Aspirant
It’s from AT&T, a Pace model 5268AC
- plemansMay 29, 2020Guru - Experienced User
Which has an integrated router.
You'd need the pace put in "passthrough" mode to disable its routing functions.
Or the orbi put in the Pace's DMZ.
Or the orbi put in AP (access point) mode so only 1 router is in router mode.
- craholtzMay 29, 2020AspirantI’m not sure how to do any of those things
If you're planning on setting it on the Pace, the best bet is to contact att. They can walk you through it. there's guides online as well like this:
https://www.att.com/support/smallbusiness/article/smb-internet/KM1188700/
if you plan on putting the netgear in access point mode then the guide for the device walks you through it.
