craholtz
May 28, 2020Aspirant
Compatibility with AT&T UVerse
Is Nighthawk Dual Band Mesh WiFi 6 System - 2 pack (MK62) compatible with AT&T
May 29, 2020Guru - Experienced User
Which has an integrated router.
You'd need the pace put in "passthrough" mode to disable its routing functions.
Or the orbi put in the Pace's DMZ.
Or the orbi put in AP (access point) mode so only 1 router is in router mode.
craholtz
May 29, 2020Aspirant
I’m not sure how to do any of those things
