craholtz
May 28, 2020Aspirant
Compatibility with AT&T UVerse
Is Nighthawk Dual Band Mesh WiFi 6 System - 2 pack (MK62) compatible with AT&T
craholtz
May 29, 2020Aspirant
I’m not sure how to do any of those things
May 29, 2020Guru - Experienced User
If you're planning on setting it on the Pace, the best bet is to contact att. They can walk you through it. there's guides online as well like this:
https://www.att.com/support/smallbusiness/article/smb-internet/KM1188700/
if you plan on putting the netgear in access point mode then the guide for the device walks you through it.
- craholtzMay 29, 2020AspirantWhat’s the difference and what’s recommended?
