AMCooper63
Mar 29, 2021Tutor
Configure AT&T ARRIS BGW210-700 with EAX80 AX6000 WiFi Range Extender
I am attempting to get my AT&T Gate Way ARRIS BGW210-700 to recognize my Nighthawk EAX80 AX6000 WiFi Range Extender as a Mesh Client with a wired backhaul. I think that I have everything configured correctly. 2.4 and 5Ghz radios are on the same channel, using the same SSID, with the same WAP2 password. They seem to work. As I move from the AT&T GW to near the Nighthawk, the WiFi signal strength will go up and down as I move. Given time, my devices seem to switch between the AT&T and the Nighthawk. It it seems it should be more fluid. Also the AT&T GW does not recognize the Nighthawk as a mesh client.
Any thoughts on how to get the AT&T GW to recognize the Nighthawk as a mesh client?
It only functions in mesh mode when ran in extender mode. That's what allows the smart roaming to function properly.
In AP mode, you can set it with the same ssid but the smart roaming doesn't function the same.
the only current devices that function with a hardwired backhaul and smart roaming are the Orbi series or MK nighthawk series.
the BGW210 isn't a mesh router.
You have the EAX80 hardwired into the BGW? If so, the eax80 should be in access point mode. If thats the case, you shouldn't have them on the same channel.
If the EAX80 is in extender mode (connected wireless to the router), then it uses the same channel. Otherwise it can cause interference between the 2
- The BGW210 isn't a mesh router.
It certainly shows that it is a mesh router. See the screen shots I supplied. Oops, I see that my PNG screen shots did not show. Nor do JPGs show. I'llhave to attache files. - You have the EAX80 hardwired into the BGW?
Yes, it is hard wired. - If so, the eax80 should be in access point mode.
It is in AP mode. - If thats the case, you shouldn't have them on the same channel.
My understanding is that you must have them on the same channel to work as a mesh system.
