yagil's avatar
yagil
Connecting 2 sets of MK63
Hi,
I have purchased 2 sets of MK63, thinking I can configure 3 MS60 satellites to single router.
However no matter what I do, I am not able to hook up the third satellite to the main router.
I tried adding through the app, but it only keeps blinking white until I keep getting red led.
To be frank, i am not sure what I will do with the other router and satellite, however that is a different story.
Any tips would be appreciated.
Thank you
Yagil
thanks
  • michaelkenward's avatar
    michaelkenward
    Unfortunately, that thinking isn't quite right. You can't just put two routers together.
    Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
    This explains some of the other drawbacks.
    What is Double NAT? | Answer | NETGEAR Support
    Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit. But that has its own drawbacks:
    Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
    • yagil's avatar
      yagil
      Thank you Michael,
      In fact, I don't need nor wish to connect 2 routers (that in fact would be more simple for me, as you said, I can build a bridge and configure a NAT, have done that many times).
      I have bundle 1, router + 2 satellites, running and all is good. What I try to do it take from the bundle 2 only 1 satellite and link it to the router which is already of bundle 1.
      I hope I expressed myself better.
      Thank you
      Yagil
