DinoHerc
May 03, 2023Aspirant
Connecting multiple Nighthawk systems
I need to add another satellite to my MR60 Nighthawk Mesh WiFi System. It did not seem as though I could buy just one satellite, so I purchased a second system. Of course, this system has a different...
- May 04, 2023
I connected the new satellite to router via ethernet and the two boxes shared enough info that when I disconnected the wire they were still happily connected. Problem solved.
DinoHerc
May 04, 2023Aspirant
- FURRYe38May 04, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡 - michaelkenwardMay 04, 2023Guru - Experienced User
Good to know.
Pity you had to buy a new bundle to get there.
Netgear needs better marketing to support people who want extra satellites.
