Ffebles
Dec 12, 2020Tutor
Connecting Nighthawk c7000 & Orbi mesh
My husband and I both work from home. We want to put my husband’s office down in the basement and my office upstairs. His system requires he be hard wires to a router. What is the best way to connect ...
- Dec 15, 2020
it is compatible but uses the slower 866mbps backhaul versus the 50 series has a 1733mbps backhaul. Makes a little difference for peak wired speeds or if there's multiple wireless devices simultaneously using it. I've used both and never had an issue with the RBS40V in comparisons to my 50 series devices. You can always swap the rbs40v for the rbs50 satellite if the office is needing the faster backhaul.
Dec 12, 2020Guru - Experienced User
Which orbi did you buy? (model)
What is your home made of and how big is it? certain materials block wifi so its tough to say "yes, it'll work" based off your info.
You have several options when it comes to setup. If you want to retain the C7000 then to prevent a double nat, you'd want to put the orbi in access point mode. This prevents running 2 routers in router mode on 1 network.
https://kb.netgear.com/30186/What-is-Double-NAT
https://kb.netgear.com/000061927/What-is-the-difference-between-router-mode-and-AP-mode
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
also, make sure you have the c7000 and the orbi on different wireless channels to prevent interference
