VorisJ
Oct 11, 2020Tutor
CONNECTING TO ROOMBA 960
I cannot get my Roomba to connect with my MR60 Nighthawk mesh wifi 6 router. The Roomba needs to connect to 2.4GH and Roomba tech support thinks it's only picking up the 5.0GH. Is there a way I can ...
- Oct 12, 2020
Got it working. I deleted and reinstalled the app. It connected and finished the installation process.
VorisJ
Oct 11, 2020Tutor
It doesn’t, but tech support told me the Roomba will only connect to 2.4GH. During setup is ask if I want to join the roomba’s network. I select join and then it says connected to Roomba. As it keeps going, it says there was a problem could not connect and retry. Even rebooted the Roomba to factory settings. Now before I got the new WiFi mesh, it use to work on my old router and WiFi.
VorisJ
Oct 12, 2020Tutor
