gamesetnmatch60
Jun 21, 2022Initiate
Constant DHCP IP to MAC address logs
Hello - This started happening last week. Im getting constant DHCP IP to MAC address logs from various devices on the network. Any idea ? I believe it's causing the network to drop eventually. Please...
Jun 23, 2022Guru - Experienced User
Please remove MAC and any WAN IP addresses from your content before posting in public forums for security reasons.
What devices do you have all connected?
How many devices do you have connected?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Try setting up some IP address reservations on the MR for your devices?
- gamesetnmatch60Jun 23, 2022Initiate
- Motorola MB8611
- Spectrum
- pretty much every type u can think of - but Im thinking the smart switches (plugs / Tuya) are causing most of these log messages
- 40
- 2000
What is the distance between the router and satellite(s)?- 30
- I did try this but it didnt help much
