Rneal1973
Jul 28, 2024Guide
Constant Speed Issues
First, thank you, Netgear, for the confusing branding. Logged into my system's UI, the main unit is an MR80, the satellites MS80 -- Searching by either of those results in no hits. But sure enough, t...
Jul 29, 2024Guru - Experienced User
So rebooting fixes the issues?
How frequently does it happen?
What gateway do you have from Verizon (they're notorious for combo gateways with built-in router)
