Rneal1973
Jul 28, 2024Guide
Constant Speed Issues
First, thank you, Netgear, for the confusing branding. Logged into my system's UI, the main unit is an MR80, the satellites MS80 -- Searching by either of those results in no hits. But sure enough, t...
Rneal1973
Jul 29, 2024Guide
I'm really not sure how we've gotten so off topic. 😁
I was being a smarta$$ in that a likely way the average consumer will get the model of the equipment is through the web UI. By linking sites to the specific models (not the kit) and linking a post to another user where it shows the MR60 (not, for example MK6x), you're reinforcing my point. See screenshot where the individual device is not found via search.
Let me say it differently -- Netgear should make the individual devices searchable and not just the kit. Most users are likely unaware they need to search for the kit if they want to associate the underlying individual device(s) to their post.
I'd almost think you're trolling me, but I know you're a well-informed responder to countless other posts on these forums. I think we've just gotten our wires crossed. 🤣
Rneal1973
Jul 29, 2024Guide
Specifically searching for the individual units in the forum posts, not on the support page. I sent a screenshot, try it for yourself, reply to this/create a new post, search for MR80, you won't find it -- that's all I'm saying.
Not using Verizon's gear.
