BELF_61's avatar
BELF_61
Follower
Jun 24, 2020
create wireless bridge with 2 EX7300
Hi Could you tell me if it's possible to create a bridge between 2 EX7300 : - 1 connected to internet box by RJ45 in access point mode - 1 connected to the first one by WIFI And if this bridge is...
  • plemans's avatar
    Jun 24, 2020
    You can connect 1 extender to your router in access point mode and then the other extender to the 1st one.
    In access point mode, mesh mode doesn't work. So you wouldn't be able to use mesh mode for all 3 devices. Just whichever one the extender running in access mode connects to.
