Leeber-tea
Oct 16, 2025Aspirant
Creating 2.4GHz and 5GHz channel
The Nighthawk App used to show both channels and I was able to put certain devices on my Guest Wi-fi for all my 2.4GHz needs, while other devices remained on my 5GHz channel. Now I cannot find a way ...
- Oct 20, 2025
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-routerEnjoy. 📡
Oct 16, 2025Guru - Experienced User
What NG router model do you have?
Is this the MK series MESH system?
