Leeber-tea
Oct 16, 2025Aspirant
Creating 2.4GHz and 5GHz channel
The Nighthawk App used to show both channels and I was able to put certain devices on my Guest Wi-fi for all my 2.4GHz needs, while other devices remained on my 5GHz channel. Now I cannot find a way ...
- Oct 20, 2025
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-routerEnjoy. 📡
Leeber-tea
I've checked this router login previously,
but it keeps pushing me to the NH App instead. I tried it again since you suggested it but I'm not sure what to do beyond the App.
Oct 16, 2025Guru - Experienced User
NH app isn't required to configure the MR router.
Just log into the MR at 192.168.1.1 with a wired PC and web browser.
If you see the 1st web page display using the NH app, scroll down to the bottom of this page and look for the link that says don't have a mobile device.
