Leeber-tea
Oct 16, 2025Aspirant
Creating 2.4GHz and 5GHz channel
The Nighthawk App used to show both channels and I was able to put certain devices on my Guest Wi-fi for all my 2.4GHz needs, while other devices remained on my 5GHz channel. Now I cannot find a way ...
- Oct 20, 2025
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-routerEnjoy. 📡
Oct 17, 2025Guru - Experienced User
I've never seen the app or GUI simply "allow you to move them to the guest". Usually, it just allows you to set up the guest network, and then the device must connect to it. Maybe I've missed something because I prefer the GUI to the app but I think you have to change which you or a guest connects to.
maybe FURRYe38​ knows more about this.
