Leeber-tea
Oct 16, 2025Aspirant
Creating 2.4GHz and 5GHz channel
The Nighthawk App used to show both channels and I was able to put certain devices on my Guest Wi-fi for all my 2.4GHz needs, while other devices remained on my 5GHz channel. Now I cannot find a way ...
- Oct 20, 2025
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-routerEnjoy. 📡
Leeber-tea
Oct 17, 2025Aspirant
Logging in to Router allows so much more access to everything and that was a success. I managed to set up both the 5Ghz and 2.4Ghz networks, however, there is one app (device) that does not want to behave. I cannot seem to locate it under the 2.4 from the 5. This lighting bridge only connects via 2.4. I wonder if I can remove the device altogether from the MR, but it just seems strange that I don't have the option to move any of my devices to whichever network I choose. Prior to this latest NH App, I was able to move devices around via the app and had the lights and bridge working fine. Oh well.
Oct 17, 2025Guru - Experienced User
Leeber-tea wrote:This lighting bridge only connects via 2.4. I wonder if I can remove the device altogether from the MR, but it just seems strange that I don't have the option to move any of my devices to whichever network I choose.
You can connect the device to a specific network name/SSID - though that is done in the device itself.
If you are using the same SSID for 2.4 ghz and 5 ghz, then there is no way to provision this in any Netgear router. But the lighting bridge won't connect to 5 ghz, since it sounds like it only has a 2.4 ghz radio. So there is no need to set up anything special in the router.
You should check your security settings - is the router set up to allow WPA2+WPA3? Or is it configured to require WPA3? Many older devices don't support WPA3.
