Leeber-tea
Oct 16, 2025Aspirant
Creating 2.4GHz and 5GHz channel
The Nighthawk App used to show both channels and I was able to put certain devices on my Guest Wi-fi for all my 2.4GHz needs, while other devices remained on my 5GHz channel. Now I cannot find a way ...
- Oct 20, 2025
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-routerEnjoy. 📡
Leeber-tea
Oct 20, 2025Aspirant
Good morning to all. Thank you very much for being such a great support. I managed to figure it all out and not only is my router solid with itemized channels, but now my lights work great. I'm very happy with my M70 Mesh and Nighthawk and Netgear stuff. Just for information sake, a substantial error on my part of the troubleshooting process occurred on the device site. I failed to scroll low enough to see the Remove Device option on the bridge. Removing and reinstalling allowed the bridge to connect automatically to the 2.4G channel. Dumb mistake but it's fixed. Thanks again to everyone.
- FURRYe38Oct 20, 2025Guru - Experienced User
