Uno_Time
Nov 28, 2021Aspirant
Customize Wifi Network issues on 2.4Ghz on a Netgear Nighthawk Tri-Band Mesh (MK83)
I am having issues with Customize Wi-Fi Network. Below is some of the stats HW: Netgear Nighthawk Tri-band Mesh MK83 Firmware: Vi.1.6.10_3.1.97 Wi-Fi Channel is set to Auto Guest Network is ...
Uno_Time
Hey,
I already disabled all the settings and the NAT is off on the modem as indicated. The system has been run fine for about 6 months before I decided to create a customize network. Everything else is running great. I can't use the customize 2.4 network.
Uno
Nov 28, 2021Guru - Experienced User
What happens if you remove the MS from the wired back haul and try setting up the MS wirelessly then try the customize the 2.4Ghz wifi?
- Uno_TimeNov 28, 2021Aspirant
I have done that. Same behavior and huge performance hit with my home.
Uno
- FURRYe38Nov 28, 2021Guru - Experienced User
What is the distance between the router and 📡 satellite(s)?- Uno_TimeNov 28, 2021Aspiranthey,
not sure how far apart, house is around 3500. they don’t see that far apart, not sure it matter because they are Ethernet backhaul .
Thanks,
Uno
