tunthura
Apr 02, 2022Aspirant
DATA SPIKE TO 2 TB WITH XFINITY
Good day all, Our cable & internet service provider is Comcast. Internet speed is 600 Mbps. I have been using my own Netgear Nighthawk cable modem CM1150V and Mesh Wi-Fi 6 router MK 63 with Comcast...
Apr 03, 2022Guru - Experienced User
With as much data as you're using, it should be fairly easy to track. shut off all your devices and turn them on in groups of 5 (ish) and then watch them for a day. If the data spikes on that group of 5, you know its one of the devices in there causing it. then its pretty simple to track.
Plus both android and windows have a built in data tracking feature you can use on those devices to see how much data they're using. I've had to use that before to find issues on one of my devices that had a miner installed and was burning through data.
tunthura
Apr 03, 2022Aspirant
Hello,
Thanks for your advice & appreciate it.
