dchow78
Oct 28, 2020Follower
Devices not connecting to closest Satellite (Nighthawk Wifi 6 Mesh) resulting in Bad Connectivity
This is in regards to the Nighthawk Wifi 6 Mesh Router. I've got a few devices that always seem to connect to the faraway Router instead of the closest Satellite. I've got a 2.4 GHz-only Secu...
Christian_R
Nov 03, 2020NETGEAR Employee Retired
Hello dchow78,
As you mentioned, the Nighthawk Mesh system does not support this feature. However, if you recently purchased the device you may try contacting our support team. Ultimately the client will decide which access point to connect to. You may try moving the satellite closer for the ground camera.
https://www.netgear.com/support/default.aspx
Christian
