Bradster
May 30, 2020Tutor
Devices on mk62[mr60 and ms60] become invisible to each other
I have two google homes, a chromecast, two phones, and a desktop connected to my network. The desktop is the only one wired. On occasion, the LAN seems to be split into two networks for my devices be...
aadiit
Jun 06, 2020Initiate
Came here searching if I was the only one with this issue. I have 3 Chromecast and 2 phones (Android and iPhone). Sometimes one of the Chromecast won't connect to wifi at all. And if connected I am unable to cast anything. The issue is random, it can be any Chromecast and any phone. Earlier I had ISP provided router which ran flawless except that it didn't reach with enough strength in some rooms. The mesh wifi 6 is having good strength but this Chromecast issue is painful
- cdelat01Aug 22, 2020Guidei have the same issue. the problem is the satellite. if you turn off the satellite everything works fine. the sad thing is it cuts off my yard. i have a case open but no fix so far.
- aadiitAug 22, 2020InitiateI just gave up and ended returning the system. What's the point of mesh system if I have to keep satellites disconnected
- cdelat01Sep 04, 2020Guidethey sent me new satellite and do far that one is working fine. what ever was wrong with mine had to be hardware and would also explain why so few folks have posted on this issue.
- MasterChSep 15, 2020AspirantSame issue with two MK63 (mine and a friend kits). Chromecast and Google Home speakers became unavailable for casting.
Each Google Home can talk with their respective Chromecast, the one right on the same room.
