Bradster
May 30, 2020Tutor
Devices on mk62[mr60 and ms60] become invisible to each other
I have two google homes, a chromecast, two phones, and a desktop connected to my network. The desktop is the only one wired. On occasion, the LAN seems to be split into two networks for my devices be...
shaun_s
Jan 02, 2021Star
I've been having similar problems. I've had the router for a few days now. At first I thought the problem was random then I did further testing. I'm quite sure the problem is related to the 5GHz wifi on the SATELLITES.
I have the MK63 (MR60 router and two MS60 satellites) with each node placed in SEPERATE rooms. I have 3 media devices (Google Home speaker, Google Home Mini speaker and Google Chromecast) and a few phones. The Chromecast is connected to the router, the Home to satellite 1 and the Mini to satellite 2. All devices are configured properly and connected to the internet. I have the latest firmware (V1.0.6.102) on the router and satellites.
The good news: No matter which node my phone is connected to, I can cast to a device connected to the router (Chromecast in my case). Also, if my phone is connected to the router, I can cast to all devices in the house. If my phone is connected to a satellite then I can cast to a device on the OTHER satellite (the speaker in the other room in my case), as well as to the device connected to the router. All is fine up to this point.
The problem start when my phone AND media device are connected to the SAME satellite. So when I'm next to a speaker I CAN'T cast to that speaker. Furthermore, the problem only happens when the media device is connected to the 5GHz band. (When the speaker uses the 2.4GHz band, the problem goes away.)
So does anyone out there have a solution?
Hey Netgear, Has anyone looked into the problem? It's been a while since the initial post. Is a new firmware with a fix available soon?
MarkH123456
Jan 21, 2021Guide
What shaun_s describes is EXACTLY my problem as well.
The Chromecasts can only be discovered by devices connected to either a different station or a different band.
I have tried:
as sugegsted by Netgear support:
- disable AX
- adjust 2.4Ghz: channel 11 and 5Ghz: channel 44
- MTU size: 1492
- enable RIP both directions (https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/Chromecast-and-Mesh-Routing-issues/td-p/1946485)
None of the above fixes the problem. Netgear support suggest contacting Google.
- MarkH123456Jan 22, 2021Guide
Hi everyone,
I may have a solution. After trying various settings and spending an hour chatting to Netgear support, I found a thread where someone noticed the error after an upgrade. So I performed a downgrade to the version prior to theirs, and lo! it seems to have fixed the Chromecast problem. I haven't read through the release notes, so I am not encouraging people to open up potential security holes, but if you want Chromecast to work, this is what you can try. Also, I only just performed the downgrade and test, so can't confirm 100%, and will check back in after a week with more findings.
This process takes about 15-30 minutes and will take the router offline several times, so do this when its least disruptive to your smart home / office / fellow residents.
To manually update the firmware:
- Go to https://kb.netgear.com/000061928/MR60-MS60-Firmware-Version-1-0-4-96 and download both files. Unzip these somewhere you can find them (I left them in the downloads folder).
- Make sure that your router is connected to your router via ethernet cable. Make sure your laptop is fully charged or connected to power. Do not use wireless connection - This process is only valid for a computer that is connected wired directly to the router via ethernet cable
- Turn off the wifi on the computer (only use the ethernet cable for communicating with the modem).
- Open a web browser and enter www.routerlogin.net or 192.168.1.1
A login page displays. - Enter the extender admin user name and password. (If you have changed these, then they will be the changed ones, otherwise it is the default admin/password)
The Status page displays. - Once your logged in go to Advanced > Administration > Router Update > Manual Update
- Uncheck the option 'Router Auto Firmware Update'. Click on Apply (this will take a few minutes and take the router offline)
You will need to do the downgrade for the base station (MR) and each satellite (MS). - Click the Browse button, then locate and select the firmware file that ends in .img or .chk starting with MR.
- Click the Upload button. There will be a big warning message that this version is older that your current version. Press the accept / OK / proceed anyway button.
- The firmware update starts and the router restarts. The firmware update process takes about two minutes.
Warning: After you click the Upload button, DO NOT try to go online, turn off the extender, shut down the computer, or do anything else to the extender until it finishes restarting (interrupting the update process may render your device into an unusable brick). When the router finishes, you will need to log-in to the router settings page again. - For each satellinte:
- Click on the IP address of the satellite in the list below the Upload button. A new window/tab should open, enter the same router password as before.
- Browse > find the file that ends in .img or .chk starting with MS.
- Upload. Same warnings as above, be patient, get a cup of coffee or tea.
Once all the satellites are downgraded, test the devices on the network. All of mine reconnected automatically, and the Chromecasts were discoverable and more importantly usable, whether the mobile was connected to the same or a different station. You can unplug and turn the wireless connection back on your computer.
I hope all this helps. :)
- cdelat01Jan 24, 2021GuideCall support have them reference case #43114555. Hopefully they will provide you the fix for the issue.
- MarkH123456Jan 27, 2021Guide
Hi cdelat01 , can you share a bit about what #43114555 is about? I sent this to Netgear support but they closed the case. When I opened a new case and again mentioned your ticket number, they gave me instructions to do a factory reset. ???
- SuperMario28Feb 04, 2021AspirantI am having the same problem as well. I have a wireless printer along with Google home/chromecast devices that are invisible to my phones and each other when connected to the satellites but everything works when my phone is connected to the main router. My parents have the same issue as well. Did the downgrade in firmware end up working?
