larry3706
Aug 06, 2020Guide
DHCP IP Address assignment MR60
I have been having some connection issues with my thermostats, not to my LAN but to the ecobee servers. I found that reserving an IP address for the thermostats seems to have resolved the issue, but ...
Dennyi
Aug 12, 2020Tutor
In the DHCP setup, change the starting IP address to a higher number. I use .130.
That leaves the random dhcp assisned number to xxx.xxx.xxx.131 - xxx.xxx.xxx.(whatever the Ending IP Address is set to).
Any Reserved DHCP IP address's you want to assign goes below the Starting IP address. The system will not try to assign a different device to the reserved IP address that way.
Just don't to add a reservation to the same IP as the router is assigned.
- larry3706Aug 12, 2020Guide
Thanks very much for a response. The conflict I was having was before I reserved an IP address, still in the lower numbers. Since I reserved addresses for the two devices, the router has not tried to automatically assign those reserved addresses to any other device. But, if I run into trouble again, your fix looks perfect.
Larry
