imrlumley
Oct 29, 2023Aspirant
Dlna server not appearing on wifi
Dlna media server not appearing on wireless network. I tried to upgrade and downgrade firmware as per other discussions. Server appears and works just fine on wired devices in same vlan. But no wirele...
- Nov 20, 2023
Well this was an exercise in frustration.
I can say that the Nighthawk APs do not appear to be at fault.
The issue "suddenly" resolved itself and the DLNA servers suddenly started appearing to all of my wifi connected devices.
I am going to assume this was some issue with IGMP on the Cisco core switch.
I cannot reproduce the issue. Various combinations of disabling and re-enabling IGMP on the switch interfaces, vlans, and global config on the Cisco do not seem to reproduce the issue with DLNA broadcast not appearing on the WiFi segments.
So everything is working just fine!
*(bangs head softly against the server rack and curses Cisco yet again)
imrlumley
Nighthawk mesh Mr60 and two MS60.
michaelkenward
Oct 30, 2023Guru - Experienced User
From what I can see, the MK63 does not have a built in DLNA server.
So what server are we talking about here?
What tells you that the router is the source of the issue?
- imrlumleyOct 30, 2023Aspirant
I have been running my own DLNA server for many years on my LAN. After installing the Nighthawk mesh units, none of the clients on the wifi network can find the DLNA server. Seems the Mesh APs may be blocking the broadcast from the DLNA server.
I have used minidlna, mediatomb, serviio, and others on the LAN. I also launched bubbleUPNP on and an android connected to the wifi SSID. bubbleupnp server hosted on the android on wifi does appear to my client DLNA devices on wifi; The DLNA server on the wired LAN does not.
Typically I would configure previous wireless APs as network bridge mode. The MR60 is operating in "access point" mode.
- michaelkenwardOct 30, 2023Guru - Experienced User
That pushes everything back to the router to manage.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
Netgear probably expects people to use routers as routers.
Maybe you need to look into the configuration of your main router.
- imrlumleyOct 30, 2023AspirantI don't need any of the router/firewall features. I need to know if the APs are blocking multicast from LAN to WiFi in AP mode. My firewall is upstream from the vlan and IP subnet that is shared by all attached devices on wired and WiFi on the core switch. The APs need to allow multicast properly in AP mode. If they don't, the WiFi devices will never discover the media server.
