salquint
Oct 11, 2021Aspirant
DLNA server not found when connected through MR60
My network was working with a primary router, R8300, and a couple of other routers used as wifi bridges. The R8300 was set up with a USB drive to provide my videos with the DLNA media server enabled...
- Jan 28, 2022
Hi!
I simply solved updating the MR60 and the MS60 to the latest firmware. Unfortunately, my devices didn't find the update, so I had to update them manually:
https://www.netgear.com/support/product/mr60.aspxCheers
spartan15
Jan 28, 2022Aspirant
Hi!
Cheers
- FURRYe38Jan 28, 2022Guru - Experienced User
Thanks for letting us now. Other users have reported problems with v122 FW so NG may have pulled this from being auto updated on MK systems. If your system is working, keep it.
Enjoy. 📡
spartan15 wrote:
Hi!
- salquintJan 28, 2022Aspirant
That's good, I guess the 6 weeks I spent back-and-forth with support got a fix in, since the update I did back then didn't do it. I moved on to the eero 6 instead, it doesn't have the device switching problem that the MR60 does... and I definitely didn't appreciate a Netgear product having such a basic traffic movement bug.
- spartan15Jan 28, 2022Aspirant
I totally agree with you, I have spent countless hours trying to resolve this DLNA issue. Also, this is supposed to be a "high-end" product, since it is a nighthawk series. I hope nothing like this happens again in the future.
