salquint
Oct 11, 2021Aspirant
DLNA server not found when connected through MR60
My network was working with a primary router, R8300, and a couple of other routers used as wifi bridges. The R8300 was set up with a USB drive to provide my videos with the DLNA media server enabled...
- Jan 28, 2022
Hi!
I simply solved updating the MR60 and the MS60 to the latest firmware. Unfortunately, my devices didn't find the update, so I had to update them manually:
https://www.netgear.com/support/product/mr60.aspxCheers
spartan15
Jan 28, 2022Aspirant
Hi!
Cheers
Jan 28, 2022Guru - Experienced User
Thanks for letting us now. Other users have reported problems with v122 FW so NG may have pulled this from being auto updated on MK systems. If your system is working, keep it.
Enjoy. 📡
spartan15 wrote:
Hi!
Cheers
