salquint
Oct 11, 2021Aspirant
DLNA server not found when connected through MR60
My network was working with a primary router, R8300, and a couple of other routers used as wifi bridges. The R8300 was set up with a USB drive to provide my videos with the DLNA media server enabled...
- Jan 28, 2022
Hi!
I simply solved updating the MR60 and the MS60 to the latest firmware. Unfortunately, my devices didn't find the update, so I had to update them manually:
https://www.netgear.com/support/product/mr60.aspxCheers
salquint
Jan 28, 2022Aspirant
That's good, I guess the 6 weeks I spent back-and-forth with support got a fix in, since the update I did back then didn't do it. I moved on to the eero 6 instead, it doesn't have the device switching problem that the MR60 does... and I definitely didn't appreciate a Netgear product having such a basic traffic movement bug.
spartan15
I totally agree with you, I have spent countless hours trying to resolve this DLNA issue. Also, this is supposed to be a "high-end" product, since it is a nighthawk series. I hope nothing like this happens again in the future.
