NathRao78
Aug 16, 2021Aspirant
Does routerlogin.net work over ethernet?
[I still cannot put in MR60 as the router model.]
On the desktop connected to the router by ethernet, when I try putting in routerlogin.net as the address it goes to Netgear website. That says that I must be on the same wifi network as the router. Does this mean that the router does not recognize the address if it comes via ethernet port? I thought it worked last year when I got the router. [It does work over wifi on laptops.]
Thanks in advance
Nath Rao
1 Reply
what modem/gateway is the router connected to?
Have you tried using its ip address? The default is 192.168.1.1 but if you changed it or are in a double nat, it could have changed.
