AK89
Jan 13, 2023Aspirant
DoS Attacks - MR60 Mesh Router
Model Version: MR60 with 2 MS60 Satellites Firmware: V1.1.7.134 Home network Two nights ago, we were kicked off our entire network around 1 am. We logged into our router the next morning and...
Jan 13, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
The logs mean that the system is working and reporting what it saw and blocked it.
Might look up and do a whois on those IP addresses that you see for those attacks to see where they are coming from.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
AK89
We got rid of our ISPs modem a while back but what we are currently using is a Netgear CM1000.
Cable between modem and router is indeed a CAT6 cable.
I just looked up the following IP address and its associated with company called Deepintent Inc.
[DoS attack: ACK Scan] from source 169.197.150.7,port 443 Friday, Jan 13,2023 12:47:05
This was from a few minutes ago.
IP associated with Oath Holdings, Inc.
[DoS attack: RST Scan] from source 209.73.190.12,port 443 Friday, Jan 13,2023 12:19:15
We've unplugged the modem and the router several times but I'll try doing it again.
I want to make sure I'm understanding your request correctly.
To do this I need to log onto my router, select Advanced > LAN Setup > Use Router as DHCP Server needs to be checked off > Set Starting IP Address to 192.168.1.100 > Set Ending IP Address to 192.168.1.200 ... or is that incorrect?
- FURRYe38Jan 13, 2023Guru - Experienced User
Correct on making changes to the LAN DHCP service.
Something also you can do, disable or uncheck all Logging options on the MR for items that you don't need to review or have the router log. It's like VPN, devices accessing allowed or blocked sites if you don't have these setup. I usually un check log items that I don't need to look at.
For your CM modem let see how that's doing. Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router- AK89Jan 13, 2023Aspirant
Okay, I've unplugged modem, router, restarted PCs then went in and set the IP address pool for DHCP as shown in screenshot below.
Here is a screenshot of the modem's connection status and modem's event log:
Please post a copy and paste of the modems connection status:
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-routerI see lots of Criticals that needs to be looked at by the ISP to resolve them.
