JohnG48
Mar 13, 2023Aspirant
Epson printer won't connect to closer satellite on mesh network
I have an Epson WF-4820 on a 2.4GHz frequency with my Nighthawk mesh wifi 6 system. I have a satellite about 6 feet away from the printer, but the printer wants to connect to the main router upstairs...
Mar 13, 2023Guru - Experienced User
How many MS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR and MS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
