James_C
May 05, 2020Follower
Ethernet backhaul for two satellites with Nighthawk WiFi 6 Mesh RBK62/63
Is it possible to use two Nighthawk satellites (MS60) wired (using ethernet backhaul) to one router (MR60) via an ethernet switch? Ethernet backhaul is supported by Nighhawk RBK62/63 (according ...
Christian_R
May 07, 2020NETGEAR Employee Retired
Hi James_C,
We have not received reports of the MR60/MS60 not being compatible with a switch. You should be able to accomplish this.
Christian
- mjcalabreseMay 14, 2020Apprentice
I am also looking to connect my MR60 and MS60 using Ethernet Backhaul but (since I have no cabling in my home) by using Powerline Adapters and Netgear GS105NA 5-port GigE LAN switches between the devices. I have seen no instructions on how to connect them other than the picture of the two devices connected with a 2-foot cable between them ... I have MK62-100NAS running 1.0.4.92 firmware level.
On initial install, the MR60 was setup on channel 11 (2.4) and 153 (5.0), but the MS60 was using Channel 7 (2.4) and 153 on the 5.0) ... after several reboots and syncs they now match -- channel 11 and 153. Not sure why any 2.4 Ghz device would use channels other than 1-6-11, but these sure did and there is no way to set the channels on the MS60 ...
- mjcalabreseMay 20, 2020Apprentice
So, just a follow-up on this topic, that I have my MR60 and MS60 connected via Ethernet Backhaul now ... It was pretty simple (and yet complicated). My MR60 is connected to a GS105 Unmanaged 5-port GigE switch and that is connected to a Powerline adapter. The MS60 is connected to a 3rd Powerline Adapter directly and because the MR60 and MS60 were connected via 5GHz already, they just converted to the Ethernet connection without any issue(s).
- Christian_RMay 22, 2020NETGEAR Employee Retired
Thanks for the update and happy to hear you got it up and running!
Christian
