James_C
May 05, 2020Follower
Ethernet backhaul for two satellites with Nighthawk WiFi 6 Mesh RBK62/63
Is it possible to use two Nighthawk satellites (MS60) wired (using ethernet backhaul) to one router (MR60) via an ethernet switch? Ethernet backhaul is supported by Nighhawk RBK62/63 (according ...
mjcalabrese
May 20, 2020Apprentice
So, just a follow-up on this topic, that I have my MR60 and MS60 connected via Ethernet Backhaul now ... It was pretty simple (and yet complicated). My MR60 is connected to a GS105 Unmanaged 5-port GigE switch and that is connected to a Powerline adapter. The MS60 is connected to a 3rd Powerline Adapter directly and because the MR60 and MS60 were connected via 5GHz already, they just converted to the Ethernet connection without any issue(s).
Christian_R
May 22, 2020NETGEAR Employee Retired
Thanks for the update and happy to hear you got it up and running!
Christian
