lucaspfmoreira's avatar
Aug 15, 2022
Ethernet backhaul for two satellites with Nighthawk WiFi 6 Mesh RBK62/63
I am having an issue with a managed Unifi network when I connect an MS60 to the US-24-G1 switch.
Any special VLAN I have to configure/allow?
I am using the MR60 and MS60s as access points.
Thanks.
  • FURRYe38's avatar
    Be sure your wiring the MR and MS using the following configuration:
    https://kb.netgear.com/000061710/What-is-an-Ethernet-backhaul-connection-and-how-do-I-set-it-up-on-my-Nighthawk-Mesh-WiFi-6-products
    VLAN would be configured or needed for the MK system in AP mode using ethernet backhaul. Be sure any green ethernet or IGMP protcols are disabled on the swtich.
    Be sure your using a good quality LAN cables CAT6 is recommended.
    • lucaspfmoreira's avatar
      lucaspfmoreira
      versions are:
      MS60: V1.1.6.122_2.0.58
      MR60: V1.1.6.122_2.0.58
      When I plug in the MS60 to try a wired backhaul it created a loopback (seems like it, can't confirm yet), and the network comes down.
      • FURRYe38's avatar
        How is the switch connected to the MR and MS. The MS needs to be connected behind the MR, even if a switch is in use, the switch should be in between the MR and MS.
        Check this by connecting the MS directly to the back of the MR with a ethernet cable.
