Brinssl's avatar
Brinssl
Follower
Jul 20, 2025
Ethernet cable required for MS70 satellite?
I have an MR70 and one MS70 satellite (which is connected to TV via Ethernet cable). I need to add another satellite for better coverage, but my house is not wired for Ethernet. If I purchase another MS70, will it require an Ethernet cable to connect to the router? I appreciate any guidance, but please explain simply. I have very little knowledge of WiFi.
  • No. The MS70 satellite will connect to the router using WiFi (the default).  Users have the option of connecting satellites to the router with Ethernet.
  • Plug in the new MS70 satellite in the area where you want better coverage.
  • CrimpOn's avatar
    CrimpOn
