dlfuller's avatar
Aug 24, 2022
Ethernet Connection to Satellite if MR60 is in AP Mode
My ISP (Verizon FiOS) setup depends on their modem not being set to bridge mode.  So the MR60 is setup in AP Mode.
One satellite at the greatest distance was initially setup with a wired ethernet connection, the other not.
I tried the routine to sync the two satellites, but the wired one would always end with a red led.  So, I disconnected the ethernet and synced it as wifi to get it working.  The router itself is IP 10.0.0.1.  The previously wired satellite now appears as 10.0.0.7.  I think it had been on 192.168.1.x before with the ethernet connection.
Is there any value in the ethernet connection to the satellite?
Any comments appreciated.
  • The ip address its getting from your verizon gateway as the MK system is in access point mode.
    so as long as the router/satellites are in the same IP range, its fine.
    Hardwired backhaul does have benefits as the hardwired connection tends to be a bit faster/more stable than wireless.
    But you have the 80 series MK so it has the dedicated backhaul. So its a toss up if you've got a solid wireless backhaul to which works better. Then it comes down to actual testing speeds because different things can impact the wireless backhaul.
    Once you have them sync'd, you can always try hardwiring it back in and giving it 5 (ish) minutes to re-sync over the wired backhaul.
    Is your switch directly connected to the MR80 or is it going through the verizon gateway?
  • plemans's avatar
    • dlfuller's avatar
      dlfuller
      Tutor
      Thanks plemans.  And my apology, I don't know what happened to my earlier reply.
      My router is a MR60, not an 80 series MK.  But I believe it does have a dedicated ethernet backhaul.  The catch is the one you pointed out – my attempt with ethernet for the satellite was with its connection to a network switch and not directly to the MR60.  There is no practical way to do that with the way the ethernet cable has been pulled.  So a moot point.
      Now "dummie" questions to check if I've got this right – I  do have two local IP ranges with this setup – 192.168.1.x ethernet and 10.0.0.x wifi and can communicate between them using the appropriate IPs?  The Verizon gateway (router) assigns an 192.168.1.x IP to the MR60 in bridge mode which then also connects the 10.0.0.x IPs and both IP ranges can communicate with each other and the internet?
      Thanks again for your insights.
      • plemans's avatar
        If they have 2 separate ip ranges, they're still in the double nat. If the MK system is in access point mode connected to your primary gateway, it should be getting an ip address in the range of the gateway
