Daniel_Fisher's avatar
May 23, 2021
EX6250 (AC1750 Dual Band WiFi Mesh Extender) - Will two work together?
Hi, this is a quick and (hopefully) easy one.
I have an EX6250 AC1750-WIFI MESH EXTENDER and absolutely love it!
However, I have a large house and could benefit from another one in towards the rear of the house to give better WIFI coverage in the backyard.
My question is - Will two of these devices work together on my network? (I assume they will, but don't want to waste the money if they don't)
Thanks for your assistance.
1 Reply
  • plemans's avatar
    They will.
    I usually don't recommend it but if you're going to do it, try to set them up in a star configuration and not daisy chained.
    Star: extender<------router------->extender
    daisy: router----->extender------>extender
    in daisy chain, your latency increases quite a bit and your speeds drop a lot.
