Tgpine
May 09, 2020Tutor
Extending R7000p
Hi it seems like every situation is unique so here is mine. R7000p firmware v1.3.1.64 download 100mbs 9mbs up 5gHz network 86 mbs 9mbs up 2.4 gHz I wish to extend my network 60 feet ...
- May 09, 2020
I wouldn't "break into it" / use a splitter.
Just get a simple 4-5 port gigabit switch and connect it. then run one cable to the cabin and the other to where the cable was going
Tgpine
May 09, 2020Tutor
Plemans thanks for the response
I have not bought an extender yet. That is what I was planning on next and was looking for guidance.
I figure I can return the extender if it doesn't work.
The power to the garage does not come from the house comes directly from pedestal
I was hoping to try this out before the decision on running the cable was needed.
The electrician will be running some wiring from the house (3 way garage light switch)so I would run the wire when he is running that. Want to have ring camera in garage also.
I could place the extender very near a window and have run a long Ethernet cable to that location or over WiFi. I imagine Ethernet is better? But is there an issue the extender with Ethernet vs WiFi?
May 09, 2020Guru - Experienced User
Tgpine wrote:Plemans thanks for the response
I have not bought an extender yet. That is what I was planning on next and was looking for guidance.I figure I can return the extender if it doesn't work.
The electrician will be running some wiring from the house (3 way garage light switch)so I would run the wire when he is running that. Want to have ring camera in garage also. ----
If your electrician is already digging in a cable and is willing to let you drop in a ethernet wire for no extra charge, I'd do that everytime. Worth every penny as its going to have better performance, more stability, and better paths for upgrade in the future.
Again, not sure if they'd charge or not but the cable is <$100. And that's close to the price of 1 decent performing range extender.
Daisy chaining wifi is a way to have spotty, unreliable, slow speeds. You could probably make it work fine but it might cost more than dropping in the cable and using an extender or older router in access point mode in the garage. You're ring camera would appreciate it and so will you.
- TgpineMay 09, 2020Tutor
Plemans,
Well that makes life easier. I am in a rural area and the electrician was just going to run it off the cable box. I think he was talking about RG 6. Do you see any issues with this? He has told me before, "l do not know much about that internet stuff", so he does not exactly breed confidence. Just need internet, stream TV.
thanks again
tgpine
- plemansMay 09, 2020Guru - Experienced User
RG6 is coax wire, not ethernet.
If your cable box enters the home, he can run a direct burial ethernet cable and just poke it in the house at the cable box entry point.
something like this.
https://www.amazon.com/Outdoor-Waterproof-Ethernet-Direct-Shielded/dp/B06XSV65TG?th=1
- plemansMay 09, 2020Guru - Experienced Userunderground RG6 could be used and a little cheaper but then you'd need moca adapters (ethernet over coax). So probably more expensive in the long run.
