Tgpine
May 09, 2020Tutor
Extending R7000p
Hi it seems like every situation is unique so here is mine. R7000p firmware v1.3.1.64 download 100mbs 9mbs up 5gHz network 86 mbs 9mbs up 2.4 gHz I wish to extend my network 60 feet ...
- May 09, 2020
I wouldn't "break into it" / use a splitter.
Just get a simple 4-5 port gigabit switch and connect it. then run one cable to the cabin and the other to where the cable was going
Tgpine
May 09, 2020Tutor
Okay feeling closer to solution. I am in a 100 year old cabin. I was able to run a Ethernet cable from my R7000p on the first floor through the basement to another location also on the first floor. I can not run another Ethernet from the R 7000p as there is not enough space in the chase way. I could break into this Ethernet in the basement and then through a splitter run one to the garage and reconnect the Ethernet net run I broke into? Issues? Thoughts?
tgpine
May 09, 2020Guru - Experienced User
