ljcrompton
Aug 17, 2022Aspirant
Firmware update - Nighthawk MR60
Hello, I have had an email from Netgear telling me there is a new firmware update for my Nighthawk MR60 however when I go into the Nighthawk app to check for updates it says there are no updates av...
michaelkenward
Aug 17, 2022Guru - Experienced User
ljcrompton wrote:
Hello,
I have had an email from Netgear telling me there is a new firmware update for my Nighthawk MR60 however when I go into the Nighthawk app to check for updates it says there are no updates available.
The on-board check for new firmware is unreliable. It can miss updates, especially when you are a long way behind the latest. It can also be a while before updates hit the automated update servers.
The best way to check is to visit the support pages for your device and to look at the library of available updates.
Support | NETGEAR
Feed in your model number and look for firmware for your device.
The release notes should also tell you how to manually update the firmware.
MR60 / MS60 Firmware Version 1.1.6.124 | Answer | NETGEAR Support
Or read this:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
- ljcromptonAug 24, 2022AspirantThanks Michael
