Perege
Dec 11, 2021Star
Firmware update failes on satellites
Hi all. I have downloaded the firmware 1.1.6.122 for my MK63 system. The instructions says that I have to start with the satellites first. But I get the message: This firmware file is incorrec...
- Dec 11, 2021Your picture shows you're trying to update the satellite firmware to the router. Not to the satellite
Dec 11, 2021Guru - Experienced User
did you extract the file prior to trying to upload it?
https://www.netgear.com/support/product/mk63.aspx
