Perege
Dec 11, 2021Star
Firmware update failes on satellites
Hi all. I have downloaded the firmware 1.1.6.122 for my MK63 system. The instructions says that I have to start with the satellites first. But I get the message: This firmware file is incorrec...
- Dec 11, 2021Your picture shows you're trying to update the satellite firmware to the router. Not to the satellite
Perege
Dec 11, 2021Star
Yes. To CHK-file.
Perege
Dec 11, 2021Star
- plemansDec 11, 2021Guru - Experienced UserYour picture shows you're trying to update the satellite firmware to the router. Not to the satellite
- FURRYe38Dec 12, 2021Guru - Experienced User
For your future needs, Netgear has set up a community forum specifically for the NightHawk MESH products. Most of the people who watch that forum are more likely to have experience with NH MESH products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
Thank you.
Perege wrote:
- PeregeDec 13, 2021Star
Great.
Thank You ππ
