mjmohsen's avatar
mjmohsen
Getting a wired gig connection on the router seems impossible
Hey all,
I have a Nighthawk Mesh WIFI 6 router with 2 satellites, and so far it has worked wonderfully well.
Today I was finally able to update my fiber connection to 1 gig from my ISP, and I'm not getting teh expected performance on the router.
I get around 550Mbps at the router port. (acording to teh speedtest on the QoS page. (QoS turned on or off makes no difference)
When i bypass the router and connect my cable from my ISP directly to my computer, i got up to 1.3 Gbps.
Any ideas on what the issue could be?
  • Here's how I solved my speed issue:
    I have an older R8300 router, that i set to factory settings, and while it also doesn't recognize the speed is full gig, it strill transmits that to my wired computers
    I now use the Mesh 6 system as an access point for the other router.
  • mjmohsen
    No help from the data sheet that I can find as it only states 'Experience the next generation of WiFi 6, perfect for medium to large homes up to 4,500sq.ft.† and internet speeds over 100Mbps, I'm on 500Mbt & expecting an upgrade soon so would be interested in knowing the limitations
    knightz01 (Kev)
  • plemans's avatar
    which actual system do you have? There's several wifi 6 mesh versions.
    What fibre gateway was installed?
    you can try factory resetting the primary router and then reinstall it. During the install, leave access control, traffic monitoring, qos, and parental controls all disabled. Try testing the speed after the install and minimum changes to the settings.
    • mjmohsen's avatar
      mjmohsen
      The NightHawk one, Models are MR60, and 2 MS60s (router and 2 satellites)
      The gateway is irrelevant as the signal coming in has the correct speed, and the issue only happens on the router itself. If you must know, the fiber signal comes from Ziply Fiber.
      I'll try refreshing the router to factory settings,
      • plemans's avatar
        Gateway isn't "irrelevant".
        If its a gateway with its own integrated router, it could be using its own form of qos to limit speeds.
        Its why we ask.
